question about valve cover gaskets
I just bought a 2000 A6 2.7T that has 90K miles. Overall, the car was maintained fairly well - regular oil changes and typical service. I am getting ready to replace the valve cover gaskets on it as well asthe suction pump (which I'm pretty sure caused the vlave cover leak) and spark plugs.
While I have that much apart is there anything else I should consider replacing?
A "buyer's check" @ the local stealership revealed that my secondary air pump is weak?
Also, what is the general concensus on oil? @ 90K should I go synthetic or is there a certain weight/ viscosityI should go with?
Thanks for the input.
RE: question about valve cover gaskets
very dubious ( secondary air pump weak?? ) now how do they make this decision ( have they done tests on the engine?? ) if so what was the results.
could it be your rocker cover gasket bolts need nipping up like 8lb-ft
Thanks for the info...any other items come to mind please let me know. This is not a job that I want to repeat if I can keep from it.
I've got the Bentley's manual on it's way so knowing where the rocker cover bolts are located will definately help.
Thanks again.
Thanks again.
dave quik question ,,,by the rocker cover bolts do you mean the hold down bolts? do they loosen and a retighten could stop the leak ? and i keep reading about tensioner gaskets but looking at the bently i didn't see them ,or missed them ?
Do a search on www.audiworld.com for replacing camchain tensioner gaskets. They are notorious for leaking.
