quattro not working?
Old 01-09-2013 | 08:30 PM
hxgaser's Avatar
How are your tires? The best 4WD system will not get you out of anything if your tires are crap.
Old 01-10-2013 | 08:13 AM
Timon's Avatar
The tires are almost new snow tires with steel studs.
Just talked to some guy at Audi and he said they are just crappy. Even with quattro it will be stuck if one wheel is spinning.
So nothing wrong with the car, just extremely poor 4x4 system :-/
Next car: Grand Cherokee with ARB air lockers
Old 01-10-2013 | 04:16 PM
ECS Tuning's Avatar
Sponsor
Many people confuse quattro with 4X4, our cars are AWD. Quattro uses a Torsen diff. Or "torque-sensing" diff.
Below is the wiki page for more information.
Click HERE
Below are some videos that demonstrate the usages of quattro.
Jason
Old 01-16-2013 | 02:57 PM
oldmots's Avatar
From 95 up to your model and up to 06, the A6 used a Gen IV AWD system comprised of a center torque sensing diff and open diffs front and rear that use traction control through the ABS to transfer torque from spinning wheels. The Center diff can transfer up to 75% of the available torque from front to rear depending on which axle has the most traction. Individual wheels are controlled by the ABS by automaticallty applying the brake of any wheel that is spinning. If yours has spinning wheels that don't stop, your Electronic Diff Lock (EDL) is not working. The center Torsen diff may or may not be working as well, you will have to have it tested to find out for sure.
clark.am2
04-08-2012 09:42 AM
BlackRaptor
12-03-2007 08:18 AM
theperfecto1
03-16-2007 04:16 PM
frankinstyn
03-15-2007 01:23 AM
GFA6
03-11-2007 02:01 PM
Quick Reply: quattro not working?
