PRNDS only on reverse, need advice!
Car: 2003 Audi A6 3.0 Quattro
Pulling code: P0706
Hello, I've started having a problem with the PRND flashing and the car going into limp mode ONLY when I go into reverse.
Now, the car does reverse when this happens, but when I go into drive the acceleration is sluggish until I restart the car and put it right back into drive. So basically the car runs fine unless I initially go into reverse. To add to that, SOMETIMES if I hold the shifter in a specific position, the reverse works without causing the car to flash PRNDS.
I was wondering if anyone else has come across this particular issue? I understand it could need a range sensor replacement, but could it possibly just be a matter of readjusting or cleaning a few things?
Pulling code: P0706
Hi,
does it go into reverse with a real lump when it does this, as mine does exactly the same thing and when I plugged in my Snap On scanner it came up with lock solenoid not disengaging.
Pulling code: P0706
Pulling code: P0706
