Power Steering Noise, Any help???
Old 10-05-2007 | 08:39 AM
Michael Knight's Avatar
Default Power Steering Noise, Any help???
Hi guys
I have got a 2001 A6 2.4 (130000 km /81000 miles) and my power steering has started to make a noise.The irritating humming noise has been increasing the last week and sounds even more whilst turning. I have checked the powersteering fluid leveland there is no air in the system or seal leaks. How does one determine whether it is the pump or rackthat is causing the noise?Ihave read an articleonreplacing thesteering fluid could resolve the problem. Has anyone tried it?Does anyonehave more advice?
Many thanks
Mike
Old 10-05-2007 | 08:45 AM
techbod's Avatar
Default RE: Power Steering Noise, Any help???
how did you check for air in the system? jack both front wheels off the ground and without the engine running do a full steering lock left to right while topping the fluid up
Old 10-05-2007 | 09:25 AM
Our local mechanic told me I should check for bubbles in the fluid while the car was idling. Do you reckon the noise will decrease by replacing the fluid?
Old 10-05-2007 | 09:32 AM
techbod's Avatar
could do but bubbles isn't the answer because when the engineis running you wont see any because the fluid is in motion, proper way is to do it as I said, bubbles or froth means the system has air in it or its been done wrong
Old 10-07-2007 | 06:39 PM
Schwarz Teufel's Avatar
Funny thins I was just visiting this site due to the same issue.I've got a 01 A6 2.7 Quattro with 65500 Miles.
My car just started to make the same noise just out of the blue. One thingI have to metion is that the weather just got a bit cold here where I live. Now I don't know if there is any co-relation but not long ago I just had the Timing belt service done and the CV boots L& R.. I think it isthe "70k miles".
Prior to that the car had been noiseless. Is this normal ? or did they miss something when they were putting it back together?
jokemjokester
10-31-2013 10:44 AM
juju4uofa
03-12-2013 07:03 AM
Murph's law
B7 Models
02-11-2012 11:46 AM
arman123
04-06-2009 02:56 PM
smussani
01-16-2007 07:14 AM
Quick Reply: Power Steering Noise, Any help???
