Pop sound from Tie Rods/Tie Rod Ends
1998 A6 2.8 Quattro, 145k
If I turn my steering wheel back and forth I get a pop sound. My buddy thinks it is the Tie rod/Tie Rod ends. I jacked up the car and there is a little play in the passenger side front tire. I had the Tie rods replaced about 2 years ago and my buddy said they should have not gone bad that quickly. My question is there anything that needs to be tightened before I go replacing parts? Also can you just replace the knuckle? Any help would greatly be appreciated.
Thanks
Thanks
Thanks
Thanks
The tire has a little play side to side. I did not see anything ripped when I took off the tire. I had a shop look at the car about 6 months ago and they said to get rid of the pop, I only heard occasionally then, was to tighten the steering by removing the battery and tightening something. The shop didn't really go into detail as to what it was. I want to see if I have a real issue here. I don't want to be driving a car that is not safe.
Solved - Steering rack was loose
