PLEASE HELP! Tranny oil change
I did what many have done... drained the tranny instead of the motor. ANyway, fixed the motor with fresh new Mobil1. Where is the tranny fill hole on my A6 2.7T 2001 Tiptronic?? What oil should I use. I only drained the pan. I am not flushing the whole thing I just need to get backon the road ASAP!! I only have 58k on the car so I am not concerned with a whole flush right now. PLEASE HELP ME!!
I need to get tranny oil back in my daily driver NOW!!!
Thanks
Thanks
RE: PLEASE HELP! Tranny oil change
Look here :http://sonolithics.com/files/a6_links.html I am not able to accuratly explain where the fill hole is. Somewhere in that website you will find a writeup with pictures.
Jeff
Jeff
Jeff
Jeff
http://www.audipages.com/Tech_Articl...nsmission.html
There should be a 2 in 1 plug one inner & out outer. You need a pump....
If you do this wrong, the car will not shift properly, & it will randomly shift out of gear on you.
Audi_Skydiver
10-26-2007 08:24 PM
