Oxygen Sensor B1 S2 Procedure
RE: Oxygen Sensor B1 S2 Procedure
i dont have any pics, but the sencor is on the passenger side, kind of hidden from the mass air sencor and the engine
on the bottone theres this big tube and youll see it sticking out
you can tell right away its the censor
Hey Audiphobic
I need to do both of mine. If you put the front of the car on jack stands you'll see them in front of the secondary Cats. The trouble I found was getting the wire harness removed as it runs all the way to the firewall up front. Most of the harness is on top of the transmission so you cannot see what you are doing, all by feel. This was another reason, appart from being a third of the price, to get the Bosch universal replacements so I can just remove the old ones and cut them off without removing the whole harness. The replacement units are exact oe units and come with a splicing kit, so there is no soldering etc. In fact I've read you do NOT want to solder the O2 wiring as it can intefere with the signals.
I got mine at http://www.rockauto.com
Let me know if you are interested and I can get you the part numbers.
Cheers
Massboykie
Cheers
Massboykie
drft1
07-05-2010 01:18 PM
