Outer grill cover
Solved
Ok, all the posts and mentions found via Google were not very clear. I did manage to solve it. Here's the real deal: With a screwdriver pop the left side tab and gently pull out the left side of the grill cover. (this is for driver side grill cover). Then there are 2 tabs hidden on the far right of the grill and in some cases if you pull the grill towards the middle they come out....they didn't in mine. So I gently inserted a flathead screwdriver between the bumber and grill cover and gently worked it. Eventually it popped out and revealed the easy to replace fog lamp assembly.
flynnr
07-05-2010 04:48 PM
Pitts.PAAUDI
05-23-2009 12:18 PM
