Oil Temp Problem
Old 06-08-2004 | 12:34 AM
audiman's Avatar
Default Oil Temp Problem
I have a little broblem with my oil temperature. When the car is started and not moving, it shows in the lower area on the gage, when you accelerate a little bit (right below 1000rpm) the temp needle goes up all the way instantly. If let off the gas peddle agian, it drops down again. Does anyone know the probelm?? Thanx
Old 06-08-2004 | 05:05 AM
ImolaS4's Avatar
Default RE: Oil Temp Problem
Sounds like an electrical short of some sort.
Do you mean that if you rev the engine above 1000rpms that the needle acts normally?
Old 06-08-2004 | 11:40 AM
audiman's Avatar
No, if the rpm is below 1000 rpm, the temp needle normal. As soon as RPM passes 1000, the temp jumps to 350 degrees.
The car is 1998 AUDI A6 QUATTRO 2.8L V6
Old 06-08-2004 | 01:15 PM
ImolaS4's Avatar
Yeah, that sounds pretty obvious to me that it has to be some sort of servo and/or electrical problem. I'm not an expert in that area, so I can't advise any further on a remedy - outside of taking it in for service at a reputable Audi service center.
What year, model and engine do you have?
Do you have access to a VAG-COM? Maybe a VAG diagnosis could shed some light.
vta62.7
05-17-2009 07:45 PM
bvgoosedd
09-05-2008 02:20 PM
fritz
08-14-2007 03:55 AM
ADubyaD
09-22-2006 10:40 PM
hoonee46
08-06-2005 10:08 PM
Quick Reply: Oil Temp Problem
