Oil Filler Cap Replacemnt?
98 A6
I have changed the the two seals on the oil filler cap, the larger rubber ring around the cap, and the smaller ring that goes around the inside cap. I am still getting some oil leaking out of the cap. It was recommended to me to just replace the oil filler cap to have the oil stop leaking out. Is this a good move? I don't just want to buy more parts I don't need.
If your getting oil outta the cap while driving, I'd suspect your PCV system is not working correctly and your pressurizing your crankcase. Carefully pull those 2 plastic hoses off the back of your valve covers and take a look for clogging.
I broke the rubber gasket on my oil cap and had to buy a new one. I called the dealer looking for the gasket/o-ring and they said they don't sell them and that I should get the newer oil cap anyways. They said the newer oil caps vent better to prevent pressure buildup. Who knows if that's true, but I bought the new one anyways.
So it might be worth the 27.00 dollars in the end.
I hadn't noticed until the new cap stopped leaking that it had been leaking, not noticeable until I took off the black plastic engine cover. It was a very minor leak, I just assumed I was sloppy when pouring oil in during oil changes. I also changed out all the pvc breather tubes a few weeks later. They were dirty but not plugged.
So I guess I solved a problem I didn't even realize I had. Also the idle smoothed out a little with the new oil cap. Then even more with the breather hose/vacuum lines. The breather hose/vacuum lines were too cracked up to be plugged.
I also had a light oil dribble that would accumulate in the recessed area of the valve cover where the filler cap plugs on.
Only replaced the top gasket and that took care of the problem, even though was a bit less wider than the OE one.
However, Jim may have a strong point related to the buildup pressure in the crankcase due to clogged breather hoses. I cleaned up mine pretty good at the time.
I thought I just chimed in with my own occurence/fix.
Yep. I took off the oil cap one day and half the gasket was stuck to the engine and the other half fell on the ground.
Thanks
