New Audi owner with some engine trouble.... yay
If one bank is misfiring and there is no code for cam position, it could well be the ignition module for that bank. Look on the air box for the two modules, swap the harnesses from one module to the other then see if the mighty VAG reports misfires on the other bank.
If anything just to say you did.
i found a warranty from warranty direct, its a 5 year warranty 100,000 for 2,146. it just a power-train warranty plus electrical components like ac and ****. it covers - -
This Contract covers ONLY the components/parts listed below:
ENGINE. (a) The following lubricated internal parts: pistons, pins & rings, connecting rods & bearings; crankshaft & main bearings; camshaft, followers & cam bearings; push rods, valves, springs, replaceable guides, seats & lifters; rocker arms, shafts & bushings; timing gear, chain, tensioners & retainers; eccentric shaft; oil pump. (b) Timing belt; serpentine belt; Water pump: Impeller shaft, bearings, bushings & housing; intake & exhaust manifolds; engine mounts & cushions; engine torque strut; harmonic balancer; flywheel (flexplate) & flywheel ring gear; mechanical fuel pump; dipstick & tube; all pulleys. (c) All lubricated internal parts of the vehicle manufacturer installed turbocharger or supercharger. The housing is covered ONLY if damaged by the Failure of a lubricated internal part. (d) Engine head(s); engine block; cylinder barrels; timing cover; valve cover(s); oil pan; dipstick & tube, ONLY if damaged by the Failure of a lubricated internal part.
TRANSMISSION. (a) All lubricated internal parts contained within the case(s). (b) Computer modules & solenoids; filler tube & dipstick; vacuum modulator; internal linkage. (c) Transmission case, transfer case & torque converter case, ONLY if damaged by the Failure of a lubricated internal part.
DRIVE AXLE. (a) All lubricated internal parts contained within the housing(s). (b) Axle shafts; constant velocity joints (CV); universal joints; drive shafts; locking hubs; locking rings; supports, retainer & bearings. (c) Differential housing, transaxle housing & final drive housing, ONLY if damaged by the Failure of a lubricated internal part.
OPTIONAL ENHANCED COVERAGE (Coverage must be marked on your application page and identification card)
ELECTRICAL: Starter Motor, alternator, voltage regulator, power window motors, heater fan and front wiper motor.
AIR CONDITIONING: Compressor Motor, condenser and evaporator, compressor clutch, coil; (pulley and hoses are not covered).
i just wanted a second opinion or two on it before i decided, the limit for the engine parts is only 3300 and 2200 for tranny and 1500 for the differential 500 for electrical and 500 for ac. and that's only only thing im worried about it just doesn't seem like it would be enough limit for an Audi. Isn't the turbos failing about 6000 to fix???
Thanks for all the help btw everyone. Im going to check those ignition modules today and ill post back if anything changes
Check Engine light on 2008 Audi A6-Random misfires
I have owned my Audi A6 for less then a year and it is at the dealer for the 3rd time in four months with a "check Engine Light" The Dealer says the vehicle has random misfire, adds a fuel additive, drives it for 60 miles, keeps it overnight, does a cold start in the morning and tells me everything is ok. After going through this entire process 3 times in 4 months....It is not OK. Audi has sold me a Lemon and will not admit they can not fix the problem. I am so dissappointed in the lack of customer service that I have received from Audi of North America. I have wanted the A6 for the last 5 years, it was my dream car, but now it has become a nightmare....I have asked Audi financial for a refund for all the days my car has been in the shop. I keep getting the run around from everyone at Audi, the Dealer (Audi of Downtown LA), Audi North America and Audi Financial. Why should I be paying for a car that is constantly in the shop? Any advice? :
koenig22
Audi Q7
03-26-2014 08:54 AM
