my exhaust
I did and i remember it vividly, i now have the center resonater and rear mufflers sitting in my garrage though. Could you post a sound clip of it or a video so i could listen to it?
I once made the mistake of putting NAPA exhaust hangers on my 1996 Audi A6 Quattro 2.8L and all three of them broke, causing a grinding noise when accelerating. You could have broken exhaust manifold studs or bolts at high mileage. I used some 5/16" stainless steel bolts, which are almost 8mm for my exhaust. For studs, you can use an 8mm die on one end and a 5/16" die on the other end. You can also order metric stainless steel bolts, however the 5/16" stainless steel bolts are more common at local stores. You may order almost any stainless steel bolt from:
www.mcmaster.com/
www.mcmaster.com/
Hollow-sounding exhaust
I heard something similar in May and couldn't find a leak. When I rapped on the cats, I found that the guts were loose in one and really loose in the other. Replacing the two cats was one giant pain.
The BHP Project
03-03-2014 07:20 PM
SoQuick
01-19-2012 05:49 PM
robbib
04-04-2011 05:51 PM
lotusride
B7 Models
12-29-2009 11:44 AM
