My car is in the shop being fixed! I can use a diagnosis! HELP!!
Old 08-09-2006 | 12:48 PM
Joeski's Avatar
Default My car is in the shop being fixed! I can use a diagnosis! HELP!!
00 2.7T with GIAC X Chip, Stratmosphere Diverter Valves, Milltech Exhaust, K&N Air Filter
I was heading home in rush hour traffic maybe doing 60 MPH. All of a sudden the car started hesitating and when I hit the gas pedal the car went no where. About a second after it started the "EPC" light came on in dash board. I Pulled over immediately and started making my phone calls. I had the car in neutral and the car seemed to idle a little bit high, but it still was running, but when I hit the gas pedal in neutral, I got the same response, the engine hesitated.
After I made my calls, I went ahead and turned the car off for maybe 5 seconds. I restarted the car and things seemed to be OK. I gave it gas while the car was in neutral and the engine responded nicely. The "EPC" light went out. Seeing this I went ahead and lightly drove the car to safe place to get towed.
My mechanic has the car and is looking into it! Since I did not have an appointment, I do not know when I will have an answer.
The latest addition to my car was the GIAC X chip. I had it done about a month and a half ago. The car was incredible. It ran so well.
I also know that probably about a week prior to my yesterdays incident, the car seemed to lose some of its zip! I even mentioned this to my mechanic, but was unable to get my car in to have it looked at. I am in the process of moving but thats another story! I just KNEW the car was not 100%. Not 1 time did my "check engine" light come on through all of this including yesterday!
Am I looking at something serious? I surely could use some inout!
Thank you!
OOOO
[IMG]local://upfiles/13659/DC06AEC20C284DC7B53574CA431D2CCD.jpg[/IMG]
Old 08-09-2006 | 12:56 PM
techbod's Avatar
Default RE: My car is in the shop being fixed! I can use a diagnosis! HELP!!
im thinking its a software glitch since its been chipped Ive heard of this problem too often and it turns out to be nothing important unless the CEL comes on, I would have cleared any soft codes and just run it then checked later for any codes
Old 08-11-2006 | 11:51 PM
dankhound's Avatar
Alos check for boost leaks. A boost leak will cause almost identical conditions to the ones you describe.
hiway006
08-02-2013 12:29 AM
jonathanh916
07-17-2009 11:54 PM
pepsicolla
06-04-2008 10:13 AM
01AudiA4
04-17-2008 03:24 AM
Notahondaowner
10-17-2007 04:47 PM
