master window switch
how do you remove the master window switch on the driverfront without breaking anything on the c5,the windows in the back seems not to work when someone in the rear tries to bring them down,yet i could up front with no problems.can someone help me out
RE: master window switch
easy fix, just buy a new one www.autopartswarehouse.com item number "W0133-1735609" its only 33.45. Cheapest I've found online.
forget about what i told you, buy it from ebay right now. here is the link. its an OEM replacement http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVW
[quote]ORIGINAL: jj2345 how do you remove the master window switch on the driverfront without breaking anything on the c5.../quote]
Hey JJ
This should do it....
http://www.vaglinks.com/Docs/Audi/C5...Front_Door.pdf
Cheers
Massboykie
Hey JJ
Cheers
Massboykie
It's pretty easy to remove the switch. If I remember correctly, it's just a pressure fit. If you look on the underside of the arm rest there's a hole. Gently (but firmly) push a Philips head screwdriver into the hole and the whole switch assembly will pop upward, out of the arm rest.
Good luck.
Good luck.
