Lexus SC400 Down, Audi A6 Up
Old 09-18-2011 | 11:54 PM
CRuby's Avatar
Default Lexus SC400 Down, Audi A6 Up
On Jack Stands I Mean.
EDIT: If you want to get to the cause of my misfires, you can jump to thread #99.
As for proper cam chain roller count, see pic in thread #77. Notice that exhaust cam chain sprocket teeth are the same on both drivers side & passenger side, but the intake cam chain sprocket teeth are not the same. Search the web enough & you'll see comments about 16, or 15.5, or 15, or 14 rollers between sprocket teeth, but it all comes down to where you start the counting & where you end. This pic on #77 has it right!
OK, I'm bringing this thread over to the A6 forum thinking it may get more hits & I'll be adding onto it hopefully.
Below link was my 1st posting about the car my son & I are fixing. It lists the CEL codes we pulled.
https://www.audiforums.com/forum/gen...ighlight=CRuby
Still trying to hunt down a used (cheap) repair manual, but that's not stopping us yet, as there is lots of info on this site & others. Stripped down to timing belt to confirm it was installed correctly by prior owner. Looks right so far. Got crank & cams lined up & even pulled cam sprockets to get to cam seals. Currently in mode to clean up multiple oil leaks, before re-assy. Looks like we have leaking valve covers gaskets, cam tensioner, cam seal, possible front main seal, power steering hoses. Don't yet know for sure about oil pan & rear main seal, as to much is soaked in oil. I dread the rear main most & hope I can tell if I can avoid it. Will certainly check breather lines to confirm they're not clogged, as I've read they could help make the problem worse.
Trying my 2nd pic attempt here so I hope it comes in bigger than 1st try. Practice make perfect.
Uploaded with ImageShack.us
Old 09-19-2011 | 11:36 AM
hxgaser's Avatar
Replace the front crank seal while at it. Also I can't stress enough that you should use the lock bar and the crank pin. Sounds like you are doing that though...
Old 09-19-2011 | 06:35 PM
CRuby's Avatar
Well, not exactly, since I don't have the "official" cam lock bar. So I'm improvising. I understand that when crank aligned @ timing mark (w/ #1 @ TDC) the cam pulley flanges should be aligned horizontal w/ big hole toward center. An easy check we did was to run a string line from pulley flange to pulley flange & confirm flange hole centers are aligned. They were. Also, w/ valve covers off I can see an alignment mark for each cam that aligns to a notch in the cam. All four aligned dead center. Lastly, I rigged a bar with flanged ends to simulate the cam lock bar I've seen on-line & used this to keep cams from turning when I removed the cam bolts. Pulled the cam sprockets using a 3 jaw puller + PB blaster. Rechecked cam alignment again & they didn't move. I was surprised to see that the cam sprockets are not keyed to the cam shaft. They are simply pressed on w/o any key alignment feature. I guess audi relies on the tool to align each cam shaft rather than individually aligning the sprockets to separate timing marks.
Hxgaser: you mentioned using a crank pin. Can you explain this further? Are you referring to a puller for the crank sprocket, or a special locking pin to keep crank from turning when loosening it. Speaking of crank sprocket, I've seen a tech. warning about possible damage to the key during removal. Anyone know how common that problem is?
Audi Crankshaft Pulley - Audi Crankshaft Pulley Technical Tip
On my prior vehicles, I've lossened the crank bolt using the starter method, but I didn't do that here of course. What's the method used to get this crank sprocket off?
Old 09-19-2011 | 07:07 PM
bob martin's Avatar
"w/ #1 @ TDC" = big time fail! Its #3 at TDC.
Crank pin keeps crank from turning.
Unless you see signs of the crankshaft seal leaking, leave well enough alone. I can't remember how I got the pulley off.
Otherwise, sounds like you have it right!
Good luck,
Bob
Old 09-19-2011 | 07:19 PM
hxgaser's Avatar
Ditto on #3 cylinder...
Crank lock pin location is right above the drain plug toward the back of the motor. You will see a screw/cap that you can undo to insert the lock pin. If you have the lock pin in, then you should be able to undo the crank sprocket too.
I politely disagree with Bob on the crank seal comment. I am the living proof that my crank seal failing after 15K miles of the timing belt job. Dealer seal cost is $15. You can get an aftermarket for about $5. I say just do it.
Just my 2 cents... I have seen numerous people that popped CEL after the belt job without the tools. I am not saying you will be one of them, but there is a good chance. Also if you want to properly PRETENSION the belt, you will need the locking pin in place while the cams are locked and the cam sprockets are loosened.
Old 09-19-2011 | 10:03 PM
CRuby's Avatar
#3 at TDC? Must be a German thing. My bad. I just assumed (I know what that means!) it was #1 @ TDC. The timing mark on the crank is however aligned to the pointer on the timing cover. Thanks to you both for prompt replies. I was just out in garage scrapping off some of the oily crud. Below crank has sign of leakage (among other locations), so I plan on changing that seal w/o damaging the sprocket key (knock on wood). Also, going to do cam seals, valve cover gaskets, tensioner gaskets, etc. The PS pump for the 2.7 appears to be @ top front of engine & is also a main source of oil leaks. Expect I'll be changing the various hoses there. Also noticed a kink in the metal PS line, that looks like someone dented it. Probably pinches down to 1/2 flow area. Add that to the list too. Enough for now. Going hunting for crank lock pin location.
Old 09-19-2011 | 10:11 PM
OGBULLYLOCDAWG's Avatar
Here's the photo that I found originally that helped me located the plug without any searching:
(Courtesy of DaveInSaltLake)
That's the oil pan drain plug in the foreground, find that, look up and it's right in that area.
Make sure the o-ring comes out with the plug, or the pin won't go screw in.
Old 09-20-2011 | 02:56 PM
CRuby's Avatar
Thanks. Bob's description & that pic got me there. I found it easier to get into there by removing the left turbo air line (probably not the right lingo). Now I definitely need the crank lock pin as you guys said. So what's a good (cheap) way of getting my hands on one, & the cam support. Does this audi forum club do loans or rentals (I wish)? I see blauparts rents the tools for 7 days but must buy timing belt kit from them. Prior owner of A6 already changed belt, water pump, & pulleys in Feb. '11 (per receipts), but neglected all the leaks. Ebay lists crank lock pin but I don't know for sure if it's the right one for the car, but it looks right. VW AUDI Crank Shaft Locking Pin Tool 1519 | eBay
Not sure what to make of these codes.
Applicable : V6 . V8 engine.
Audi : AAH, AFC, AHA, AKB, ART, ATQ, AUX, AVK, AWN, AYS, BBD, BCY, BEL, BFM, BGK, BHF, BNK & BSB.
Old 09-20-2011 | 03:05 PM
hxgaser's Avatar
That ebay lock pin will work. Those codes are engine codes. Your 2.7T is APB. I am not sure why it is not listed, but it will work.
Old 09-22-2011 | 10:01 PM
CRuby's Avatar
Crank Lock pin ordered. Front brakes, rotors, CV boots, & speakers
delivered today. Paint scrapper, ~1/2 roll of paper towels, & mineral spirits got engine front cleaned up pretty good. More to do on sides, back & below. Plan to change out several leaky PS oil hoses among other things. Don't like the looks of the kink in PS line, but I don't think it's cracked cause it probably would have been leaking fluid & made a bigger mess. It wasn't me, I swear! Maybe a junkyard trip.
So, anyone care to tell me what this post is for on front lower engine right. Surely there must be a purpose for it. Looks like it just floats in the middle of a pocket on the radiator assy.
Got the crank lock plug out & found this green o-ring stuck in oily muck below it. Not sure if I dropped it when I pulled plug or it was leftover from someones prior work. Anyway, it'll get put back correctly.
While I'm fixing oil leaks & thought I might as well redo the lower oil pan gasket. Looks to be easily accessible. Haven't checked it yet, but does oil pan use a gasket, or just RTV?
Quick Reply: Lexus SC400 Down, Audi A6 Up
