Jacked up, ignition on, "P" position, and rear wheels rotate
Old 01-31-2008 | 08:18 PM
jcyj2's Avatar
Default Jacked up, ignition on, "P" position, and rear wheels rotate
Mine rear wheels rotate on Parking shift position.
Howabout you guys' ? I hope thisisnormal.
Old 02-01-2008 | 04:34 AM
Cmoney's Avatar
Default RE: Jacked up, ignition on, "P" position, and rear wheels rotate
I noticed the same thing while I was changing the pads and rotors out on my car. I asked around and people said that it's normal for the axles to turn when the tranny isn't engaged. I thought it was weird too, especially for quattro.
Old 02-01-2008 | 02:49 PM
RedShoeRider's Avatar
If I'm not mistaken:
The reason the wheels will spin freely even though the transmission is locked is because of the rear differential (one wheel spins one way, the other will spin the opposite when it's up on thejacks)True, the transmission is locked up when you're in "P", the differental is located between the wheels, not affected by the transmission. If you were to spin the wheels and look at the driveshaft, it the driveshaft wouldn't spin, even though the wheels do.
When the car is on it's own 4 feet, both wheels are trying to rotate the same way, thus forcing the differential to spin the driveshaft (it can't spin the opposite tire the opposite direction because its in contact with the ground), but that motion is arrested because the transmission is locked, thus prevening your car from rolling.
The fact that it's quattro doesn't really play into this, other than our cars having two sets of differentials and 4 half-shafts.
Old 02-01-2008 | 04:01 PM
dankhound's Avatar
Its normal. They do that sometimes with all four wheels in the air too like on a lift. The fwd cars do the same thing. I have no idea why they do it. Sometimes its easier to say act of god with these cars than it is to try and figure out why.
Old 02-01-2008 | 04:12 PM
techbod's Avatar
all the wheels will rotate if jacked up but no traction will be sent so you could stop the wheel turning with your hands same as limited slip dif
Old 02-01-2008 | 04:15 PM
jcyj2's Avatar
I saved moneythen~ huh~
Old 02-01-2008 | 04:17 PM
techbod's Avatar
simple technologyand yes you saved cash
djfame
02-26-2015 03:51 AM
Nutty
03-31-2010 04:09 PM
410ThirtyValve
10-21-2008 09:15 PM
silver_bullet
11-21-2006 01:19 AM
cork2win
04-20-2006 06:16 PM
