Intermittent no start - driving me crazy!
So I thought I had immobilizer problems (UK car - '96 A6 wagon) - replaced ignition barrel/key, reader coil, wiring and ignition switch, tested three keys - easier to start but symptoms remain:
I left it standing yesterday, started it 10 times at intervals no problem. But after a drive this morning for 20 mins, I switch off, it restarts then cuts out immediately (1-2 secs). NO flashing immobiliser light.
No immo or engine fault codes.
Any starters where I should look?
It's been 4 weeks now and I've spent over $100 on new lock/ignition switch - when it runs, it's a really great car. So damn annoying.
Thanks
- I checked fuel pump, fuse and relay - when it works all run fine. Voltage readings appear normal
- Engine coolant temp sensor - ran all the resistance tests and 'seems' ok
- Engine multi-function sender (to guage?) - was erratic before, cleaned contacts and appears to work just fine
Thanks
thanks, but (I'm sure?) C4 A6s don't have that computer, but I will check the separate alarm module in any case..
