How to reset my ABS???
Old 01-30-2009 | 12:32 AM
millenia's Avatar
Smile How to reset my ABS???
Ok guys just got my module back for one of the A6 i have. Had a code P1606 these awesome people from module master took care of it. I put it in go into the snow slam the brake, bam my abs works and eveything is good. But when i scan with my vag scanner, it still shows the P1606 code, will disconnecting the battery for the night work for me???
Old 01-30-2009 | 01:12 AM
nm3210's Avatar
Well i'll ask the obvious: did you clear the code??
Old 01-30-2009 | 01:26 AM
millenia's Avatar
yea i cleared the code and still is on when i scan it again, i think the bettery disconnection should do it but i m not sure
Old 01-30-2009 | 01:44 AM
twinturbomew's Avatar
Well the code is classified or identified as
Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction.
So check the connection or maybe they fixed one thing and disturbed another in the electrical connection. If you cleared the code more then once then disconnecting the Batt is not going to do anything. For the most part you are not going to clear any codes by disconnecting the Batt.
Try clearing the codes in the ECU then back to the ABS. There is a chance that there are multiple codes stored around the modules that are creating the code
Old 01-30-2009 | 10:07 AM
millenia's Avatar
k i ll try
Old 01-31-2009 | 11:48 PM
millenia's Avatar
no news, same results
Old 02-01-2009 | 12:31 AM
chefro's Avatar
If your Brake warning light is not on and your ABS works, I don't see why you need to worry about a code in the ECU's memory.
Did you try to clear the codes in the ECU/ECM as it was suggested? From the reply it isn't clear if you tried that or not.
peter121
03-13-2012 02:33 PM
JaceTun
09-12-2009 02:28 PM
bihoang
02-24-2007 11:54 PM
dtownhotcorner
01-31-2006 07:39 PM
