How to reset a6 4.2 transmission
Old 01-10-2005 | 02:31 AM
audigirl42's Avatar
Default How to reset a6 4.2 transmission
I've been dealing with water leak problems in my 2000 a6 4.2. Under heavy rain, water leaks into the front and back passenger footwells. Each time this happens, the transmission goes into limp mode. I would rather not take my car to the garage again (I have a file 3 inches thick on this subject and have already spent serious dollars on this car). Does anyone know how to reset the transmission?
P.S. I read a previous posting that said: turn on the key (not the engine), hold the pedal all the way to the floor for five seconds. This would reset the transmission. Is this correct?
Old 01-10-2005 | 03:36 PM
furius.styles's Avatar
Default RE: How to reset a6 4.2 transmission
i had a problem in wich my transmission was stuck in limp mode. try disconnecting the battery for about 10-15 mins then re-connecting it. make sure you unplug the black negative cable first and then the red positive one, that should take care of it.
Old 01-10-2005 | 07:55 PM
audigirl42's Avatar
Unfortunately, I've had the battery disconnected for a few days since the water damage. Do you know of any other way?
Old 01-11-2005 | 07:24 PM
Jestnomen's Avatar
6th Gear
purchase a Vag-Com from ross-tech.com.
Old 01-13-2005 | 12:14 AM
mitao2000's Avatar
i have the same problem with the water in the passanger side what are the simptoms when the transsmision goes into limp mode?thanks
Old 01-13-2005 | 03:01 AM
audigirl42's Avatar
You'll know it when it happens. The dash display for the transmission reverses color and the car will only allow operation in 5th gear or reverse. Makes it tough to get across town... If enough water accumulates in the front passenger footwell, it will get into the computer located under the carpet and cause the fault. A frequent source of the water leak is through the cabin filter located in the engine bay under the plastic cover by the windshield. How it gets into the air intake is still a mystery to me...
Old 01-13-2005 | 03:12 AM
audigirl42's Avatar
Thanks. It sounds like a good investment given all the problems I've had. Will it perform the transmission reset function as well as the diagnostics? How reliable is the company?
Old 01-17-2005 | 09:08 PM
d21212's Avatar
How common is this particular leak and is it in just the 4.2? I think one partial fix is to get the carpeting up and slide a wide piece of plastic over the computer area. Not too hi-tech but water will never know that.
Old 01-18-2005 | 01:15 AM
Jestnomen's Avatar
6th Gear
ross-tech is a VERY reliable company, always stand behind their products.
Manfred von Richthofen
B7 Models
03-25-2012 11:49 PM
millenia
02-01-2009 12:31 AM
Haligan4129
05-26-2007 05:44 PM
dtownhotcorner
01-31-2006 07:39 PM
