how to remove center console wood?
Old 11-25-2006 | 01:09 AM
zebinheimer's Avatar
Default how to remove center console wood?
does anyone have any diagrams or pictures of how to remove the wood from the center console on a 98 a6? I am going to refinish it and want to remove it the "right" way lol
Old 11-25-2006 | 07:12 PM
quattromond's Avatar
Default RE: how to remove center console wood?
How are you going to refinish it, is it scratched or dull. Mine has swirl marks on it that I would like to fix, and some scratches.
Old 11-25-2006 | 08:10 PM
it has two large cracks in the finish. not uncommon in wood trim such as this. I happen to work at a custom woodworking shop so its pretty simple for me lol. If you have scratches in it you can try removing the wood, wet sanding, or compounding it. If you have any questions about refinishing feel free to ask.
Old 11-25-2006 | 11:51 PM
Boston Driver's Avatar
Check out this post from the other week, from my brushed shift bezel mod:
A6 shift surround/bezel removal
Just pry up from the trailing edge of the shift surround and it should just pop up. Then slide rearward from under the ashtray and voila!
Old 11-26-2006 | 09:13 AM
Oh ok, well what kind of compound should I use, it has luster but has swirl marks. So I would think something light in cut right, any recomendations on something that can be picked up at the store.
Old 11-26-2006 | 02:17 PM
if the marks are real heavy you might want to start with a heavy duty compound. if they are real heavy i would go with 3m super duty compound then 3m rubbing compound after the super duty. make sure to keep track of how deep your going with the super duty as it has a fairly heavy cut. if the swirl marks are not so heavy. just the 3m rubbing compound would do. I recommend removing the would first so yo ucan get every area.
MartinCieslak1
09-15-2010 05:29 PM
seattlea6
08-06-2007 02:41 PM
pilot5.0
06-29-2007 07:29 AM
andrewbb89
12-09-2006 09:17 PM
Talis
05-17-2006 01:05 AM
Quick Reply: how to remove center console wood?
