How to check solenoids
Old 02-28-2012 | 06:08 PM
copper07's Avatar
Default How to check solenoids
Does any one know how to verify of the solenoids are good or bad? Is there a way to check this instead of just replacing them?
Old 02-28-2012 | 06:14 PM
M5S5's Avatar
Tech Certified
Which solinoids?
Old 02-28-2012 | 08:12 PM
copper07's Avatar
Originally Posted by M5S5
Which solinoids?
The 2 for the small 4mm vacuum lines.
Old 03-05-2012 | 01:21 PM
copper07's Avatar
Does any one know of a way of testing these components aside from just replacing them?
Old 03-05-2012 | 02:34 PM
M5S5's Avatar
Tech Certified
Apply vacuum on the vacuum side of the solinoid , it should hold. Then connect a ground to one side of the electrical connector , power to the other side of the connector , it should click & vacuum should go to zero.
If that happens they should be good.
Old 03-05-2012 | 04:58 PM
copper07's Avatar
I will try that to verify that they are both good and not causing the issue.
blackGM
07-25-2014 01:51 PM
pbbg
05-17-2011 01:23 AM
parlayin
02-10-2010 01:33 PM
BUCKET O BOLTS
07-28-2008 09:15 PM
