high pitch metal rubbing noise when turned lock to lock?
Old 05-12-2008 | 10:32 PM
Wayne.L's Avatar
Default high pitch metal rubbing noise when turned lock to lock?
Hi guys, I have this problem ever since I got the car, so when I turn the wheel lock to lock, I can hear a kinda high pitch metal rubbing noise, it's quite loud that I can hear it from inside windows all closed, and of course outside, the sound only come out right at both end, if I turn the wheel just a little bit off the end, all the sound are gone, and the sound it always there whether the car is stationary or moving. I checked the steering fluid and it seem right at where it should (right at the line). So what is causing these sounds? It's quite annoying cause I can hear it every single time I park the car. Will this be a costly problem to fix? Thanks in advance.
Wayne
Old 05-14-2008 | 02:13 AM
2000_2.7t's Avatar
Default RE: high pitch metal rubbing noise when turned lock to lock?
I think I have a similar problem.
Old 05-14-2008 | 01:38 PM
NH_USA's Avatar
You are bottoming the power stearing. Just don't turn the wheel so far and you'll be OK.
tomicbob
10-18-2014 01:10 PM
425macchi
03-30-2009 01:44 PM
a4riderz
11-06-2007 12:40 AM
coola3
02-15-2006 06:26 PM
