HID kit 35w or 55w and what color
Hey, I've got a 2000 2.7t with halogens. I am going to be upgrading to HID. Looking at the ddm ones. I am really debating on which ones I want between 35w and 55w. Also I want the color to be as white as possible, no blue and no yellow (at all for the yellow). Thinking their 4500k or 5000k will do the trick. Does anyone have any experience with these and their acutal results? Any input is appreciated. Just looking for a clean white look.
Thanks
Thanks
FOR OEM LOOK IN FIXTURE/ROAD:
35w = 4500k
55w = 5000k
I own both 35 & 55w DDM kits and 4500 & 5000k bulbs. In the past I had 6000k 35w bulbs and they look blue/purple. I don't care what anybody says, 6000k looks aftermarket.
Every car manufacturers headlight fixture shapes the light differently. Our 4500k 35w kit in our 3 series is very blue, but white in the A6. I don't care if your mother's sister's brother's wife's TL has 6k in them and they look great. Don't compare HIDs from any other manufacturer. They don't use the same fixture so you can't compare them.
35w = 4500k
55w = 5000k
6000k is bright white (diamond white) with 35w , aftermarket kit. should run around 80 $. mine are 8k with bluish. check on you tube some clips with colors .
Unless the pics are of Audi projectors then comparing pics online will be of no help. The 55w kit is brighter than the 35w but not as much as you would hope. But from DDM it is only 15 dollars and it definitely is worth the extra 15 dollars.
4500/5000 will not look any different than a stock C5 A6. If you want the Honda look like in the TL then go with the 35w 5k or 6k 55w.
Thanks
Thanks
SO u'd better choose 55w 6k slim hid kit http://www.vvme.com/12v-5055w-h1-hid...cPath=44_45_14 for low beam....
H7 for high beam....
