HELP! Max Tire width on A6 2001
Old 06-07-2006 | 03:16 AM
fishercounter's Avatar
Default HELP! Max Tire width on A6 2001
Would a 225/60R16 work with Stock rims and OEM equip?
Old 06-12-2006 | 12:52 AM
apfelbaum's Avatar
Default RE: HELP! Max Tire width on A6 2001
The tire itself is not only wider than the stock tire, which should fit, (I'm running 235/45/17's), BUT, the sidewall, is going to be much larger than stock. The diameter is almost an inch bigger. Might fit, but will throw your speedo way off. I would make sure nothing is rubbing, hitting or otherwise. Especially when going through dips and bumps. If you can avoid this, don't do it. The stock tire diameter is around 25", You're looking at around 26". HTH
daze614
02-15-2012 04:58 PM
nlewcock
06-04-2009 12:31 PM
warranty225cpe
12-18-2008 06:24 PM
Spawn821
02-05-2008 05:46 PM
Samer305
07-26-2007 10:28 PM
Quick Reply: HELP! Max Tire width on A6 2001
