help - changing rear bulb
Hi
one of the 2 bulbs that light up when you switch on your lights (rear light) not the break light but its all one unit. The car is a A6 2.7TDi 2006. The dealer said there is 1 screw to remove from inside which I did and the whole unit was sort of loose after I took off a plastic cover no the boot edge, but the other side did not budge, I was scared to pull hard, is there any other things I need to do to have the whole light unit come out?
thanks
krish
thanks
krish
