fuel injector cleaner?
Old 10-07-2008 | 10:25 PM
little_town_audi_owner's Avatar
Default fuel injector cleaner?
hello
i am wondering if anyone have had adverse efects or problems with using fuel injector cleaners in general and for example the gumout concentrated fuel injector cleaner i bought
i havent put it into my system yet because i was wondering if anyone had issues
thanks
Old 10-07-2008 | 10:45 PM
newaudiguy's Avatar
I have used them before with no adverse affects. IMO you will be ok. good luck
Old 10-07-2008 | 10:51 PM
2001A6's Avatar
I use the chevron wit techron stuff right before oil changes, never had any negative affects.
Old 10-07-2008 | 11:39 PM
oc_audica's Avatar
get seafoam.
Old 10-08-2008 | 06:51 AM
Kevin's Avatar
I have been happy with BG44k. The Chevron Techron is ok if you can't find BG44K.
Old 10-08-2008 | 11:02 AM
2001A6's Avatar
Two questions...
1. BG44K? What is it?
2. Is sea foam really that great? Im coming up on an oil change so its a perfect time to do this. I have read other threads about sea foam and always left with a blank look on my face. I would consider it if its not too complicated or expensive, and if it works well. I have just always heard that chevron is good stuff, but if there is somethn better, I would gladly switch.
Old 10-08-2008 | 02:55 PM
nemohm's Avatar
One could consider:
-WD-40 - much cheaper
- Liqui moly - German stuff for German cars
Custom blend:
-kerosine
-naphtha
-mineral spirits
But be aware: the application makes real difference.
The concentration is the key here.
Old 10-09-2008 | 05:48 AM
Kevin's Avatar
BG44kk is a powerful fuel cleaner used by many car dealerships. Type BG44k into you web browser and you will be directed to the manufacturers website.
Old 10-09-2008 | 11:06 AM
beefski's Avatar
I have used gumout regane on both my cars and have had no ill effects.
Old 10-09-2008 | 07:14 PM
ppgoal's Avatar
I've used it every couple months since I bought my A6 with 38k miles and it's now at 118k. However, on a higher mileage car, it could loosen up too much crap and cause problems. I bought an A4 3.0 with 70k for my daughter and tossed in a bottle. A couple times I felt it shake a little under acceleration, like it was missing. The next day I noticed the CEL on and Autozone diagnosed a P0401 (I think). It was either the catalytic converter failed or an engine miss. I suspected the latter and after about 2 weeks the CEL cleared itself.
Hockeymonkey
B7 Models
03-17-2010 11:56 PM
Diecast747
02-16-2009 04:31 PM
99A6Quattro
02-14-2009 12:00 PM
Carlos10704
02-08-2008 01:34 PM
SamJamaica
07-31-2005 02:09 AM
Quick Reply: fuel injector cleaner?
