Front passenger window problem
Old 06-20-2010 | 12:13 PM
Turbo123's Avatar
Default Front passenger window problem
Hi, I have a 2001 Audi A6 and i am having a problem with my front passenger window. When I use either the drivers door switch or passenger door switch the window starts to slow down and get stuck and then automatically go back down. I have tested the motor and I know that it is not the problem, and there are no weird noises or anything. How do I find out what the problem is? Is it the plastic brackets or the window regulator? I don't want to buy a part and have it be a different problem. Your help is greatly appreciated, thanks
Old 06-20-2010 | 01:11 PM
Jeffla's Avatar
Old 06-20-2010 | 02:22 PM
Turbo123's Avatar
Thanks, I guess I will change the plastic clips first and if that isn't the problem it must be the regulator right?
Old 06-21-2010 | 12:17 PM
Theiceman's Avatar
don't worry .. it is the clips .. there is a youtube vid on how to change them ..
Old 06-22-2010 | 08:33 AM
Turbo123's Avatar
Ok thanks
Old 06-23-2010 | 10:49 PM
Turbo123's Avatar
So It turns out that one of the clips was broken and I changed them and the window works great. Thanks for the help
Old 06-24-2010 | 08:29 AM
Theiceman's Avatar
told ya what colour were the ols ones BTW .. there have been 4 colours . I just did mine last week and the old ones were Blue. Only the rear one was busted but of course i did both. BTW buy two more cause you know what is coming ..
Old 06-25-2010 | 08:58 AM
Turbo123's Avatar
The color of the ones I replaced was blue and the new ones were like a pink. At least now I know what to do if that problem arises again.
Old 08-27-2010 | 01:05 PM
david060909's Avatar
With the same problem on A6 1998. Will the window guides be the problem. PLs advise
Old 08-27-2010 | 05:07 PM
NH_USA's Avatar
David -- what more info do you need?
They told you what the fix is!
Just follow the instructions.
littleaudi
12-29-2012 05:07 PM
imAdash
02-21-2011 05:23 PM
Jickopik
07-16-2008 05:24 PM
mjwtaylor
01-16-2008 07:01 PM
BFlan2001
07-28-2006 03:57 PM
