Front outer C/V Boot
Old 10-16-2006 | 04:22 PM
craig_mack's Avatar
Default Front outer C/V Boot
So Saturday I tackled the job of changing the torn boot on my car. what a b*^%h... that is a job I will likely take to the shop if needed again. First off the damn control arms didn't want to come out of the pinch, so after an hour or so of "persuading" it finally came loose. Then my pos puller didn't want to work to remove the c/v, so I ended up using the bolt trick, which ALMOST did the trick. So I ended up fidling with the puller until it finally worked. Now putting the joint back on was the trickiest part. I had to put it on at an angle because I didn't have any room to go straight on. What a pain, all in all it took about 3.5 hrs. , but I was helping my brother put his new headlights on his b5.
Old 10-19-2006 | 04:13 AM
Mike@PureMS's Avatar
Default RE: Front outer C/V Boot
We usually just remove the lower control arms instead, they're much easier to remove if you have stubborn pinch bolt.
Old 10-19-2006 | 03:49 PM
craig_mack's Avatar
ORIGINAL: Mike@PureMS
Does this allow more room to access the joint? Can you swing the hub/brake further out of the way by removing the bottom?
rehan1212
08-22-2013 08:28 PM
hartsoe1
12-03-2009 08:23 AM
jonnyblazz1
05-14-2008 11:48 PM
heloman28
04-19-2008 10:33 AM
x650rwc650x
07-25-2007 06:29 AM
