flashing brake light on dash
ok, so my hand brake/ebrake light started flashing (with that completely released of course) and three beep will sound only when i make a long sharp turn like those 280 degree ramp onto the freeway at relatively higher speed, but it went off after i got onto the freeway, so i did a little research on this, many said that it's low on brake fluid so i check the reservoir, and it kinda show that its empty...but I didn't quite believe that, cause on the owner's manual its said that if brake fluid drop significantly below min line brake wear indicator will come on, and you have to take it to stealer but that indication never came on on my dash but i still went to dealer n bought a can of brake fluid for 10 bucks or so then i added, but then it topped off immediately, i guess i can't quite tell the brake fluid level cause it's transparent, so since the brake fluid is full, why did the ebrake light flash?? now it got so bad that it is constantly flashing and beeping, it's so annoying...thanks in advance for any imput
What's so freekin hard about adding a bit of brake fluid??
Open the cap - pour a bit in (use the right kind) - replace the cap.
The only thing to watch out for is if it continues to go down -
If it does you have a leak and it needs to be fixed NOW!
If you don't you will be looking for a new front bumper, fenders and hood alonge with a radiator and a gazillian other small parts.
PS Plan on doing brake pads soon!
topping off the brake fluid fixed it. fine for months now.
strange how the stealer said they did that while warning that the brake pads (new 6 months ago indie shop) needed replacing soon. the light was still on after the stealer visit. i guess this scam the owner brings the car back, pays $800 for front brakes and the stealer tops off the fluid. the nnj dealers do this bleep every single time.
Everytime I take it somewhere for something minor, I bring it home with more, bigger problems from jackasses.
levimh1
01-14-2014 07:23 AM
daze614
08-13-2013 07:47 PM
jjock
09-10-2009 09:23 PM
