Error code 421
RE: Error code 421
If you DIY then clear the code and see if it comes back.
Next, change the o2 sensor & spark plugs
lastly, change the cat
The dealer did/does change the threshold (or something) for the cats, I have no idea if it applies to your issue, but you could call and ask.
RE: Error code 421
bahhh I have been holding off aswell because I have court coming up where I might not be able to drive anyways But I will ask around and ask my buddy with an s4.. I know parts for the o2 sensor $215.00.... Sadly I have been pretty stupid with getting stage 3 and not checking my spark plugs!! Def do this when replacing or checking the parts. That is fairly easy to do but let me know if you need a step by step with checking the spark plugs. Takes about10-20 mins to check since I have taken the intake out who knows how many times
