Engine knocking sound-Please Help
Old 11-07-2008 | 07:57 PM
shanritz's Avatar
Default Engine knocking sound-Please Help
Hi Guys,
I have a 2003 A6 4.2. It was running fine when I had to park it for about 4 months as I had to go away. Now when I start it I get a knocking sound from the Engine..not loud but good enough to be able to hear it when you are near the car. It goes some thing like..taka-taka-taka.. Any idea what could be wrong?
Thanks much.
Old 11-07-2008 | 09:34 PM
greenquattro's Avatar
Member
You may be able to close in on where the sound is coming from if you leave the car at idle and listen to different areas with a pipe of some sort. I have a 1 1/2" X 2' steel pipe that I use to listen for the source of noises. From there it may be easier to figure out what the issue is.
Often I've found that noises I think are knocks are really just check valves or other mechanisms that you don't notice unless you listen.
Best of Luck,
Paul
Old 11-10-2008 | 01:16 PM
NH_USA's Avatar
Probably a lifter hanging up -- Change the oil and put something like 5-20 in for about 500 miles. Let it get warm but don't drive it hard! Then change the oil and use your normal stuff. Do a filter each time....
quattro fan
09-30-2012 05:19 PM
audiallday83
07-04-2011 06:32 AM
sineo
06-11-2011 08:38 AM
connersz
09-17-2009 04:18 AM
alisterm
12-03-2007 08:52 PM
Quick Reply: Engine knocking sound-Please Help
