:: ECS Tuning :: Aluminum Oil Filter Housing Cap - Audi 3.0T/3.2L
The factory oil filter housing cap on your Audi doesn't jive with the rest of the engine bay's fine materials. The super-slick black billet aluminum cap by ECS corrects this oversight, while adding another dimension of increased longevity, durability, and ease of use.
Machined from solid T6061-T6 aluminum, the housing cover is black anodized for hardness and performance styling. The integral 21mm hex head makes it easy to remove and torque the cover using a common wrench size, eliminating the need to purchase a special-sized socket. For convenience, the cover has the correct tightening torque prominently etched in white, and uses the stock filter cartridge and sealing o-ring, requiring no special seal or gasket.
With this product, ECS Tuning R&D has thoroughly addressed the concern for oil housing cover cracks and leaks without overlooking your engine bay aesthetics.
Features List:
- Rugged cover is CNC-machined from 6061-T6 solid aluminum to precise dimensions
- Integral 21mm hex makes removal/tightening easy using this common wrench size
- Black anodized finish is attractive and durable
- Torque specifications etched in white for easy reference
Oil Slick
Click HERE to order or for more information
Fits:
Make(s): Audi
Model(s): A7 A4 A5 S4 S5 A6 Q5 Q7
Submodel(s): 3.0T / 3.2L
Chassis: B7 B8 C6 C7
Application Note: To prevent damage and ensure a leak-free oil change, ECS Tuning recommends tightening the filter housing cover to the specified torque of 25Nm (18 ft-lb)
Let me know if you have any questions.
Jason
ECS Tuning
01-15-2014 04:07 PM
ECS Tuning
Audi Q5
01-15-2014 04:06 PM
ECS Tuning
Audi Q7
01-15-2014 04:06 PM
