ECM Installation
ECM Installation
Need help as to how to remove the wiring harness from the engine control module on a 1998 A6.
Pulled the tabs out on the sides of the wiring harness but it does not seperate from the ECM under moderate pressure.
Before attempting to pry the connector from the ECM I would like to know if there is any other release or technique I should use. I want to avoid damaging the wiring harness.
