Do I need radio codes for a 2005 a6???
Old 12-19-2008 | 05:23 AM
mac5217's Avatar
Default Do I need radio codes for a 2005 a6???
I Was going to replace my battery UNTIL I had seen threads regarding the radio locking and having the right radio codes? Does this apply to a 2005 a6, or just older models?
Thanks!
Mac
Old 12-19-2008 | 07:28 AM
ezhik's Avatar
You will need the code, though in practice I've discovered that if you are quick the radio doesn't go into SAFE mode. If you're unsure, then attach a 12v supply to keep the radio, and other settings stored whilst you make the change. This is by far the best method, because then all your stored settings will be kept, without, it's possible you may need to realign a number of modules, eg, throttle body, aircon, seat memory, interior lighting mode etc
Old 12-19-2008 | 12:50 PM
nemohm's Avatar
Keep reading of radio codes and safe mode issues is of non-sense this days unless one does something extraordinary!
These times are long gone - disconnecting the battery causes only the clock to get off.
The rest of components are protected by auxiliary batteries or capacitors and do not lose their configuration.
bchena1313
10-12-2007 02:01 PM
jrodpikap
09-02-2007 04:14 PM
Awally6
08-14-2007 07:19 PM
Dana Reed
04-02-2007 09:26 PM
Superdug
12-15-2006 11:11 PM
