Cold start Idle bounce
Old 11-13-2009 | 01:10 AM
Jackmup's Avatar
Default Cold start Idle bounce
I resolved a cold start idle bounce on my A8 4.2 and wanted to post it here too because I've read a few members have the problem also.
I tried a TBA no success
codes;
P1564 Throttle actuator low voltage intermittent
P1141 Load Calculation cross check implausible
So going of the "under voltage" DTC I pulled the terminal off and cleaned it, Nothing. Then I pulled the side cover off
took a nail file to the top two terminals ans sprayed the rest with MAF cleaner and just tweaked the four lower terminals.
For those that need pictures (midniteoyl) Please scroll down.
I did mine with the TB on the manifold. I don't know if you can do them all that way. Stuff shop rags around it before popping the clips or you'll be sorry!
One of the clips
The upper terminals I cleaned with a nail file. Blow out the filings with air!
The lower ones I sprayed and bent them out very slightly so they make good contact.
The cover I sprayed
The cold start idle bounce and the surge while driving is gone. Acceleration from a stop is much smoother.
Old 11-13-2012 | 01:26 AM
t0pnotch1's Avatar
i know this is a really old post but im hoping you still go in this forum. My car started to surge and doing the same. I am hoping you can help me find where this piece is on the motor. I have a 2000 audi 4.2 a6.
thank you
Old 11-13-2012 | 08:41 AM
Jackmup's Avatar
It is on the passenger side or of the throttle body.
The throttle body is where the air comes into the engine located on the top of the intake
so you need to take the top plastic cover off.
Work slowly and tuck rags around and use magnets or those clips will disappear!
everything in there is dainty so kit gloves and be delicate.
clean all electric connections on these cars and apply dialectic grease when ever you disconnect them or have a day you feel like playing with the car.
Old 11-13-2012 | 01:17 PM
t0pnotch1's Avatar
Thank you I will try this over the weekend.
jeckel20003
02-24-2014 06:24 PM
Jackmup
01-08-2012 01:56 AM
pyradell
09-03-2010 11:32 PM
burtonboarder84
03-04-2010 07:44 PM
kaotik411
12-26-2007 11:10 AM
