Cloudy Headlight Lense
Old 11-05-2007 | 10:36 PM
mattinaz's Avatar
Default Cloudy Headlight Lense
My 2001 A6 2.8 had very clear headlight lenses until about a year ago. Now they're very cloudy and none of the polishes I've tried from Walmart, Autozone, etc. seem to work. Does anyone have a suggestion or best to replace?
Thanks,
Matt
Old 11-05-2007 | 11:31 PM
Polka Salad's Avatar
Default RE: Cloudy Headlight Lense
do you know if it is the inside or outside? if inside use 600 1000 and 2000 wet dry sandpaper from gritty to fine (600-2000) until the lens has a uniform look and then use pollish. I think i used PlastX maquires...someone has a more detailed how to here I know i just dont know who or where it is....try searching for it this is a common problem
Old 11-06-2007 | 12:16 AM
mattinaz's Avatar
It appears to be on the outside. I'll do another search. If anyone else has ideas, please share! Thanks, Matt
Old 11-06-2007 | 01:15 AM
germantech's Avatar
SoCal Crew Member
i had the same prob on the same car,I buy and sell fish tanks so what i did is went to my local pet shop and picked up the best acrylic posish they sold( it was a 2 step polish) it took a little elbow grease and about 45mins of time. But it came out like new. i repolish it every 2 mnths just to keep em clean. save the sand paper for a last result i have seen way to many cars that they could not buff the scratches out.the kit only cost about 20-25bucks....
good luck and pm me if you need a walk through, i will glad to help
Old 11-06-2007 | 02:04 AM
katcoota's Avatar
I think the headlight cleaning issue is actually mentioned in the Hints and Tips or DIY section. A good article with lots of photos.
Living currently in a sandy country, and prevention being better than cure. Once cleaned, I was advised by people who live here to use wasing up liquid to make a thin film on the lenses before long trips. Obviously, this works better in the day as night vision might be affected.
CabChick
02-21-2011 12:14 PM
pinaplebob741
09-29-2009 10:36 PM
desirableeklipseTT
10-02-2008 02:26 PM
xTTx
05-07-2008 07:22 PM
edge19lw
04-03-2007 04:21 AM
Quick Reply: Cloudy Headlight Lense
