Check Engine and Rough Idle
Old 09-22-2009 | 12:55 AM
Keithr726's Avatar
Happens to me pretty fequently, coils. Either replace all or replace one but always carry a spare! They are about $30 at NAPA or online.
Old 09-22-2009 | 09:31 AM
cuberider's Avatar
Default learn screwdriver all while saving $120
i coulda got out for $30. which smiley is holding his ankles
Old 10-16-2009 | 05:34 PM
danstr1's Avatar
Default It's fixed!
Sorry I didn't reply sooner. It was the coil as several had mentioned. All is well now. I understand the coils typically go at once which means I get to go through this 5 more times. You'd think the dealership would just replace them all while they're at it wouldn't you? My car is still under CPO but not for long. Time to unload!
Old 10-16-2009 | 05:49 PM
Jackmup's Avatar
What you need to do is save the bad coil pull back into the stealer and pull the next one out and put the bad one in 5 more times and they'll all be new
Old 10-16-2009 | 09:30 PM
Midniteoyl's Avatar
^^ Yep... put that bad one back in there every week
Old 11-08-2009 | 02:32 PM
cuberider's Avatar
Default Audi service notice and reimbursement form for coil issues
Just got a notice about coil issues for my car. Includes reimbursement form so I can maybe get $150 back.
All info is here in case u didn't get notice
audiusa.com/coils
Old 11-10-2009 | 10:39 PM
5th_year_senior's Avatar
So this is like a recall right? I am having this problem now and my car falls under the notification...
  #18
Old 12-02-2009 | 04:43 PM
swltony's Avatar
What if it isn't the coils?
I have p300,301,302 and 303.
Replaced the plugs and cables yesterday. Still idling rough, same codes and the same annoying flashing CEL.
1996 Audi A4 126kmiles
I seafoamed it today. Just not having any luck. Need to fix it for obvious reasons and also needs smog.
  #19
Old 02-04-2014 | 07:53 PM
Darylaudia627's Avatar
Default Same issue
I had the exact problem today. What did you find out it was
  #20
Old 02-05-2014 | 02:11 PM
Jackmup's Avatar
You need to pull your codes and see whats happening
p0301,2,3,4,5,6 are misfire codes.
if all of your cylinders are misfiring then it sounds like a problem that would effect all cylinders.
Fuel pressure too low, test it (if so pump or regulator bad)
Maf sensor, IAT sensor, cam or crank sensors, ~Vacuum lines maybe
do not erase any codes with a cheapo code reader instead see them all first with a VAG-COM so you get the whole picture.
Mine wouldn't start only cranked a few weeks ago.
It was the IAT sensor wiring terminal.
but the cheapo code reader did not pull that code, only my Vag-Com did.
You can not diagnose a car these days without being able to read the codes because the entire engine is controlled by a computer that is connected to sensors and usually it's an electrical issue somewhere and the computer can't get enough information to manage the engine correctly.
Outside of that, I shall use my swammie powers and I forseeeeeeeeeee...
YES! a Subaru in all of our futures
oh except for that guy wearing a blue shirt, he still has his audi and he is swearing up a storm with wrench in hand
too bad for you my friend. too bad for you.
dunnracin
05-03-2012 10:01 AM
AWD_Addict
05-18-2011 04:42 PM
OnlystreetraceAWD
12-10-2008 12:18 AM
Cranky Bastard
11-22-2007 12:51 AM
Willfulone
04-07-2006 02:11 AM
Quick Reply: Check Engine and Rough Idle
