Check engine light....
Old 02-23-2007 | 03:39 PM
jonny29's Avatar
Default Check engine light....
So last night my check engine light came on. So I went to my buddies right away and got his OBDII scanner. Hooked it up to find out that the car is throwing a code P0150, malfunction in the O2 harness or something along those lines. Anyone have any idea as to what this means?
Old 02-23-2007 | 03:45 PM
techbod's Avatar
Default RE: Check engine light....
clear the code first and see it it comes back,
P0150 = O2 sensor 1 bank 2 circuit malfunction and wiring is the most probable cause then its the sensor follwed by the ECM which I doubt
Old 02-25-2007 | 05:20 PM
jonny29's Avatar
I did clear the code and so far it hasnt come back, if it doesnt should I still be worried? Is this a major code or more along the lines of a BS code?
Old 02-25-2007 | 05:56 PM
techbod's Avatar
chances are its down to the weather so if it remains off then nothing to worry about
Old 02-26-2007 | 01:17 AM
jonny29's Avatar
Thats the same thing I was thinking about today. Ive had the car in a heated garage during most of the snow and just had it out for a couple days. These couple days is when the light came on and I figured it was just the weather, maybe some slush got in the way or something else along those lines. Thanks for the advice avant80
parlayin
02-10-2010 01:33 PM
MrTigz5254
03-08-2008 12:56 AM
huyaroo
09-12-2007 04:37 PM
blanthony
03-25-2006 02:18 PM
