check engine light
Old 07-11-2008 | 11:37 AM
reverend's Avatar
Default check engine light
yesterday i had my oil changed and after a couple of minutes afterward on the highway my check engine light came on? should i take it back and have them take a look at it?
Old 07-11-2008 | 12:56 PM
reverend's Avatar
Default RE: check engine light
input anybody? should i try and see what the codes are first?
Old 07-11-2008 | 01:07 PM
wammy18's Avatar
we are unable to give you info with out the code
Old 07-11-2008 | 01:14 PM
reverend's Avatar
alright i will try to get that then
Old 07-11-2008 | 02:36 PM
techbod's Avatar
you did an oil change and didn't reset the the interval, no big deal as long as you log it for personal reasons
Old 07-11-2008 | 02:43 PM
techbod's Avatar
service data can be bought in many places ( even I can stamp your book for you ) but I wouldn't "its a case of soul searching" personlay its worthless because it can be replicated
Old 07-11-2008 | 02:47 PM
techbod's Avatar
let me put you wide on this "receipts" for none dealer work which is better than service info
Old 07-11-2008 | 03:56 PM
reverend's Avatar
p130 and a p150 were the codes it threw. are o2 sensors immportant?
Old 07-12-2008 | 04:24 AM
techbod's Avatar
P0130 = O2 sensor 1, bank 1 circuit malfunction,
P0150 = has 2 meanings ( heated (HO2s) 1, bank 2 and the same O2 side has failed ) which means that sensor needs to be replaced,
they could be both related because of wiring and sensor fail but I would be looking at P0150 as being the cause and yes the O2 sensors are very important because they directly increase fuel consumption
Old 07-14-2008 | 03:07 PM
reverend's Avatar
i had the light turned off. if it is still wrong shouldn't it come back on?
