Check Engine Code P1392
Bentley gives you directions as to what to try next:
#19
The OBD is located under the hood (driver side, behind the firewall) in the relay box. Keep in mind that's OBD I type - two ports, so you'll need an adapter connector to use with the interface cable.
Edit: As NH said though, it is possible yours may be in the center console. The manual shows both locations as possible placements. Mine is under the hood.
