Check engine code
Old 11-16-2007 | 10:38 PM
JoJo03's Avatar
Default Check engine code
Hey everyone,I have a 2003A6 Quattro and my check engine light is on and I dida scan with the scan tool and it read out two codes, (1) evap emission control system leak very small, (2) evap emission control system purge flow fault. Does anyone have any clue on what the issues is?
Old 11-17-2007 | 09:47 PM
dankhound's Avatar
Default RE: Check engine code
Most likly you have a evap purge valve that is stuck part way open causing a leak in the evap system and improper flow from the evap system to the engine. Check to see if the purge valve holds vacuum. If it doesnt, replace it.
Old 11-18-2007 | 12:08 AM
JoJo03's Avatar
Thanks alot, what kind of effect can it have on my car in general?
Old 11-18-2007 | 11:26 AM
dankhound's Avatar
If thats what the problem is it will have minimal effect on how the engine runs.
Old 11-18-2007 | 11:41 AM
techbod's Avatar
but it will damage the catalyst so what was the codes?? the EVAP system is there to protect over fueling and damage to the cat, its a story on its own
MikeA407
B7 Models
05-17-2014 10:56 PM
ChitownSLine
03-16-2008 09:00 PM
Deekster22
09-07-2007 08:59 AM
MilitantGrunt
11-01-2006 10:16 AM
Fieldy
12-30-2004 10:23 PM
