CHECK ENG CODE P1130?
Old 11-13-2007 | 12:50 PM
AUDIA642's Avatar
Default CHECK ENG CODE P1130?
2000 AUDI A6 4.2 WITH A CHECK ENGINE CODE OF P1130...SOMETHING TO DO WITH FUEL AIR SENSOR? ANY IDEAS AND HOW TO FIX THE PROPLEM.
THANKS,
PHIL
Old 11-13-2007 | 01:18 PM
formulagigi's Avatar
Default RE: CHECK ENG CODE P1130?
is it what it read?
P1130 - Long Term Fuel Trim mult.,Bank2 System too Lean
are yuo not gettig P1128 too for bank1 system too lean?
I know someone who had both codes, dealer replaces MAF and sensor.
Are you running K&N air filter?
Check Vaccum line
Old 11-13-2007 | 01:24 PM
AUDIA642's Avatar
NO just P1130 code. Don't have a K&M Air filter...recently replaced with Fram.
Thanks,
Phil
Old 11-13-2007 | 01:31 PM
Does it ride rough or normal.
if it is a torn vaccum line on the secondary air system, which isvery common on all VAG vehicles, it will be ok to drive it. It doesnt effect drivability. Just more of an emissions thing.
Old 11-13-2007 | 02:14 PM
crazyfst02s4's Avatar
Old 11-13-2007 | 02:37 PM
AUDIA642's Avatar
Yes, vehicle runs fine. No change in response since light went on.
Old 11-13-2007 | 03:13 PM
DMSD's Avatar
Could be a vacuum leak or an O2 on bank 2. The ECU is looking at the O2s and sees it has been supplying more fuel to that side for awhile. I would check for vacuum.
Old 11-13-2007 | 03:42 PM
AUDIA642's Avatar
Will do...thanks
Old 11-08-2012 | 07:38 PM
97A8's Avatar
What was the outcome? I'm seeing similar codes now...
Srgarrett21
12-16-2011 01:57 PM
AudiLover75
04-10-2011 06:25 PM
ChadAudiA6
01-16-2010 09:44 PM
RoboRabbit
05-10-2009 02:17 AM
MilitantGrunt
11-01-2006 10:16 AM
