center dash console lights go dim as car warms up
Old 04-30-2010 | 09:56 PM
vanbragt's Avatar
Default center dash console lights go dim as car warms up
Is it a simple bulb replacement or?
Old 05-01-2010 | 08:14 PM
jhuffman's Avatar
My audi has a little dimmer switch that will dim the lights. If it happens as your car warms up its probably just a loose wire or a bad connection to that, if you have one.
Old 05-02-2010 | 03:07 PM
vanbragt's Avatar
Thanks, I will give it a try
Old 05-03-2010 | 01:32 AM
hxgaser's Avatar
Actually it is known issue. Connector for the center display is soldered to the circuit board and it becomes loose after awhile. Do a search on the forum. There are many threads, but basically it involves either sending your cluster in for a repair, doing the repair on your own, or just replacing the cluster.
Old 05-03-2010 | 11:30 AM
jhuffman's Avatar
Are you talking about the backlighting for the speedo and the tach or about the LCD display? hxgaser is right about the lcd display... I thought you meant the backlighting :S
Alexa01a4QS
03-16-2009 12:10 PM
idfnl
01-05-2008 12:09 AM
seattlea6
08-06-2007 03:41 PM
ShawnP
03-22-2007 06:34 PM
snow4fun
08-25-2006 06:13 PM
Quick Reply: center dash console lights go dim as car warms up
