car won't start
RE: car won't start
If you ghave better chance to start the engine after 10s key ON-your system has no residual fuel pressure. I've had this on my 4kq.
There should be check valve on the fuel pump responsible for holding the pressure in the system.
Not just the flow of fuel but the pressure should be tested.
Where is your fuel pump located?
RE: car won't start
The other line bleeds excess pressure back to the tank, its called a return system.
If the fuel pressure regulator was failing the engine would either run lean/rich, wouldn't cause the car to not start.
Don't worry about how long the fuel pump charges, just worry about if gas is getting to the engine.
RE: car won't start
Thanks AudiTech79 for the prompt reply!
Is there something special I should do when I put the line back together? I mean, am I supposed to put some kind of sealer on the thread to prevent leaking? Or is there a spec for torque on that? Just wanted to make sure I do it right since it is the fuel line on top of the engine.
Thanks.
Thanks.
#18
RE: car won't start
Working on pulling the feed line off, it is tighter than I thought.
Forgot to mention that after I changed my fuel filter and tried to start the first time (of course it did not start), there was fuel coming out of both inlet and outlet of the filter because I did not tighten it hard enough. Is it an indication of I am actually getting fuel, thinking there is nothing else in the line before the engine other than the pipe?
#19
RE: car won't start
Ok, verified. So, there is fuel from the pump; there is spark on the plug; the plug is dry; the engine does not start.
According to AudiTech79, it is the engine speed sensor for this scenario. Where is it? Is there any write-up that I can follow?
I have a free version of VAG-COM, I believe there is one spot you can monitor the engine RPM. Of course right now if I monitor it, it is 0 RPM; but what if I monitor it while I try to start the engine? If it reads good RPM, then the engine speed sensor is good; if it reads 0 RPM, then this sensor is bad. Is my assumption correct?
#20
RE: car won't start
Today I used my free VAG-COM to monitor the engine RPM just to verify the engine speed sensor. As I turned the key, the RPM get to 160 within a second. So the sensor is good. This made me question the way I checked the fuel line. I did not follow the instruction from AudiTech79 exactly (stupid me), as soon as I loosened the bolts for the feed line, there was fuel coming out under pressure. I assumed this was from the last fuel pump run a minute ago. But I was wrong. Today I actually disconnected the line, took a bottle and had my wife turn the key on. I realize two things:
1) there is no fuel coming out of the feed line; so the fuel pump did not run;
2) the 20 seconds of high pitch sound is not from the fuel pump, but from the engine compartment; I don't know what it is.
So now I have verified the fuse for the fuel pump, it is good; looking for the fuel pump relay but could not find it. searched the net, can someone tell me is it just behind the fuse panel? if it is, how do I take the front molding off to have access to it?
Thanks.
Thanks.
