Can an aftermarket Catalyst work?
I put on a Mr Exhaust catalyst on my A6 4.2. The code below efficiency threshold comes on since after just a hundred miles. Has anyone gotten an aftermarket cat to work? people are talking about reflashing ECU. How? spacing out o2 sensor?
I think using spark plug non-foulers may be the solution. However, did you try clearing the code see if it comes back?
About three monts ago I replaced the whole exhaust (including the cat) in my Elantra and I got a CEL within 50 miles, just as the vast majority of other people who replaced the cats with aftermarket ones reported. I cleared it and never came back.
I would say it may have something to do with a "break-in" condition, but I don't want to sound stupid.
I have reset the code many times. it comes back in about 100 miles. the car is otherwise free of issues and codes. I like the grease theory (but shouldn't it burn off from the heat?). I'll try to take out and clean the front sensor. I guess for the rear sensor, the dirtier the better?
If that doesn't work I will try the spark plug non fouler at the rear.
Thanks for the advice!
Aftermarket CAT
Just purchased an 03 A6, failed smog (P0421 & P0431) at my local shop and brought it back to the where I bought it (used car dealership). They replaced the 2 cats and the code is gone, according to my shop the new CATs are still showing a fail on the machine. They suggested to try to drive another 30+ miles to see if they "Set", this is the same thing I was told by the dealership.
Any thoughts?????? I have already driven over 60 miles on a single trip.
Your readiness code needs to set. Do a forum search.
