Cam Sensor on a 3.0
I don't know how a 3.0 engine looks like (even less on a newer model), but on the 12V 2.8 engine there's only one camshaft position sensor, and is at the rear of the driver side bank's head.
The passenger side bank only has a cam plug there.
The passenger side bank's rear only has a "regular" camshaft seal + some sort of "sleeve" that the sensor slides or fastens on:
You are right, it should have a plug, but the sensor fastens with TWO Allen bolts (if I recall correctly are 10 Metric heads):
You can actually see the fastening holes in the middle pic.
The 3.0L is a big pile of ****, i hate that motor. I've worked on more of those damn things that all the audi motors put together. There is a good reason audi only manufactured it for 3 years, then completely changed the design. While the 1.8T, 2.7T, 2.8L, and 4.2L all share the same head designes.
