C5 A6 4.2l Quattro Tiptronic Shifter Will Not Shift Into Every Gear Position
Old 10-18-2017 | 07:56 PM
Rescue413's Avatar
Default C5 A6 4.2l Quattro Tiptronic Shifter Will Not Shift Into Every Gear Position
The shift lever in my A6 will not shift fully into the drive position or any lower forward gear. The actual lever, not the hydraulic function of the transmission. The brake interlock is functioning properly and allowing the lever to come out of the park position. Nothing appears to be jammed under the cover plate in the center console limiting the functionality of the lever. Any thoughts.
Old 02-18-2024 | 11:14 PM
Peter de Cathelineau's Avatar
Sorry but I wasnt able to see a posted solution. Did you figure out what happened? I drove it 4 days ago and it was fine. Went thru carwash with underbody wash. parked it for 4 days at 20-30 F and no work today.
Lamaughan
02-22-2022 10:45 PM
Stidham
09-19-2010 06:43 PM
Stidham
09-18-2010 11:24 AM
sbbgf8
11-06-2007 05:17 PM
Quick Reply: C5 A6 4.2l Quattro Tiptronic Shifter Will Not Shift Into Every Gear Position
