C5 2.8L A6 Will Not Start
The starter motor is turning but I am not getting any spark. A few days ago the car started but I shut her down after tripping the check engine light/rough idling. I cleared the error codes listed below and now the old girl won't start. Any advice? Coil packs, fuel pump relay? Cats toast?
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 3B0 907 551 AN
Component: 2.8L V6/5V G 0050
Coding: 07552
Shop #: WSC 07208
6 Faults Found:
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
16689 - Cylinder 5 Misfire Detected
P0305 - 35-00 - -
16687 - Cylinder 3 Misfire Detected
P0303 - 35-00 - -
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 4B0 927 156 AJ
Component: AG5 01V 2.8l5V USA 3132
Coding: 00004
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes
Controller: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00031
Shop #: WSC 02325
Address 08: Auto HVAC
Controller: 4B0 820 043 K
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 4B0 920 980 L
Component: C5-KOMBIINSTR. VDO D11
Coding: 02262
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15917
Shop #: WSC 42281
3 Faults Found:
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01561 - Left Rear Door
58-00 - Can't Lock
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 07552
Shop #: WSC 07208
6 Faults Found:
P0300 - 35-00 - -
P0302 - 35-00 - -
P0305 - 35-00 - -
P0303 - 35-00 - -
Coding: 00004
Shop #: WSC 00000
Coding: 00031
Shop #: WSC 02325
Coding: 00160
Shop #: WSC 02325
Coding: 02262
Shop #: WSC 00000
Coding: 15917
Shop #: WSC 42281
3 Faults Found:
35-00 - -
35-00 - -
58-00 - Can't Lock
Coding: 00001
Shop #: WSC 02325
The car won't start due to many reasons. I guess the main problem coming out of these errors is that the fuel supply is not proper. I hope you have checked the spark plugs. Fuel pump relay could be a problem if the spark plugs are ok. If not, then the next thing to look for is coil packs. With catalytic converter and O2 sensor damaged, your car should still start, so these are not the issues I guess.
Car wont start???
With all the codes coming up, the first thing you can do is check all your fueses. To do this you will need a test light.
Secondly, it is very important that you check these fuses with a good test light. You should invest in one from power probe.
U had the same problem with my 2000 2.8 and found out that my fuse looked good but was not getting any power. I used the power probe and put power to a fuse and the car started right up. my car was down for over 6 months, 4 shops, 1 dealer that told me I needed a new ECU, . I am not saying this is your problem but you have to find out what is getting power and what is not I hope this helps you and I am free to answer any questions you may have
Thank you for the response. I hadn't had a chance to check the plugs. It was dark out when she wouldn't fire up and I just ran the codes. I will try to run the output test on the fuel pump relay. How do you determine the test failed? Is there any thing that would indicate the coil packs are toast?
Do you have individual or a single coil pack. How was the spark checked?
Answering the other question. Vag Com can do activations of the fuel pump. If the pump runs it is a good sign that the fuel pump & relay are good!
So had to bring her into the shop as I don't have spare time at the moment. They're telling me no compression and that the timing belt is toast. Is this remotely possible? Just had the thing replaced at 95,000 and we are at 120,000. Are they lying?
First off , thanks for a autoscan of your vehicle. It would help if we could get everyone to post one of these up for all looking for powertrain help.
I tried running the output test and I could not tell if the pump was functioning properly. Is there another test that I should be looking for? Activation?
Thanks
I just had the same starting issue, checked my plugs, they were carboned up. Replaced plugs and cranked the engine over and over for ten minutes. It eventually fired, blew a bunch of smoke, ran a can bg44k through it and haven't had a problem since. Found out later my wife has been running 87 instead of 91. Valves are carboned up, probably affecting compression. I might have the whole intake system cleaned.
Vict0ar
04-03-2014 09:38 PM
kinnes042
S4
04-10-2013 07:29 PM
brit.mike13
10-17-2010 09:26 PM
