Brake problem!!
Old 12-28-2007 | 09:31 AM
mpdc_1's Avatar
Default Brake problem!!
I have what appears to be a big brake problem and wanted to know if anyone else has experienced this. If I drive at highway speeds for a few minutes, the first time I press the brake pedal on the highway the pedal travelsmuch further than normal and has no brake boost. If I let off and immediately step on it again it has full brake boost assist. It only does this after travelling on the highway and not in city traffic. I checked the brake lines and fluid and I can't find any leaks. The fluid is not dropping in the resevoir at all either. Has anyone else experienced this or know what may cause this problem? I am going to have to take my Audi in because it is quite scary when I see brake lights in front of me on the highway and can't slow down!
Old 12-28-2007 | 10:33 AM
frankinstyn's Avatar
Default RE: Brake problem!!
Your problem lies in the brake booster. This operates off of vacuum so the problem may be as simple as a disconnected vacuum line. I don't have the manaul for this car yet so I can't give you any specifics.
As you said, the brakes, lines and master cylinder are fine.
Old 12-28-2007 | 02:05 PM
mpdc_1's Avatar
Thanks for the quick reply! If it was a disconnected vacuum line, wouldn't I lose brake boost all the time though? It only does it on the highway when I've been driving at highway speed for at least a good 5-6 miles or so. Either way, I need to get it fixed ASAP as it isn't a good feeling knowing that the first time you try to slow down on the highway you don't have any brakes [:-]
boosted517
10-13-2020 12:30 PM
DavidElvin
04-18-2007 03:52 PM
chongboi
08-26-2006 03:47 AM
Dudek12
12-19-2005 12:48 AM
west2005
11-07-2005 08:36 PM
