Brake light when turning
Old 11-16-2008 | 07:16 PM
2.7ta6's Avatar
Default Brake light when turning
There has been a red BRAKE light flashing and an annoying beep almost everytime i drive my car now. It is the same ligth that comes on when you use your e-brake except its flashing. I have started noticing it only does this when i take a right turn?
Any ideas?
Old 11-16-2008 | 11:14 PM
zippy_gg's Avatar
Maybe your pads are worn out and the fluid gets low in the reservoir,sending you a warning...
Add some brake fluid and check if the light comes back on.
Next time you replace your pads be careful as the level of fluid in the reservoir will rise when push the pistons back in the calipers. Use a baster to remove some extra fluid first.
Remember that brake fluid is nasty on painted surface...
Old 11-17-2008 | 10:43 AM
NH_USA's Avatar
Yes --Check the brake fluid.... make sure you use the correct type if you have to add any!
rocktbone
09-27-2012 08:45 AM
AudiBrooklyn
01-30-2011 02:01 PM
il laureato
08-18-2009 11:41 AM
jkity
12-14-2007 05:21 PM
ironman
09-12-2007 02:42 PM
Quick Reply: Brake light when turning
